ASR 903 packet drop issue
naveen_ap
Hi experts,
     I have an issue with Cisco ASR 903 router, which is generating logs as below.
IST: %IOSXE_INFRA-5-PUNT_SVC_INVALID_OPT_PKT: Invalid IPv4 options packet punted to RP
I am seeing packet drop on one interface. Please let me know how I can identify the logs above were generating due to this packet drop.
I tried to run "debug netdr" but command not taking. Is there any method to run netdr capture?
Please suggest.
GigabitEthernetX/X/X  is up, line protocol is up
  Hardware is A900-IMA8S, address is 1833.9d3c.cd97 (bia 1833.9d3c.cd97)
  Description: ### connected to the 4948-2_PORT-48 ###
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 113/255, rxload 18/255
  Keepalive set (10 sec)
  Full Duplex, 1000Mbps, link type is auto, media type is SX
  output flow-control is off, input flow-control is off
  Last input 00:00:51, output never, output hang never
  Last clearing of "show interface" counters 00:00:45
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 297
------------------ show version ------------------
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.2(4)S2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 18:07 by mcpre
IOS XE Version: 03.07.02.S
Br,
Naveen Paveri
rasche
If you have QoS enabled take a look for drops there.  Most Likely low priority queue.
