mac add being dropped
nyi gbe
Can you have two mac addresses showing on an interface? Is this normal then the switch authenticates only the first mac and the second one is drop as I see from the mac table!
5162252_SW_1_1#sh authentication interface f0/8
Client list:
Interface MAC Address Method Domain Status Session ID
Fa0/8 001f.46d1.3000 mab DATA Authz Success 0A4D1AF00001F242D6760296
Fa0/8 0040.9d2f.ea3b dot1x UNKNOWN Running 0A4D1AF00001F71BD9B3A5FC
Thx
Nyi
Julio E. Moisa
The mac addresses are unique, you could have several mac addresses on the same interface but it could be because the mac address table has not cleaned the information after a certain time or if there is a hub connected to the port.
You could configure: mac address-table aging-time seconds (it could be in multiple of 5) to clean the mac address-table periodically.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
