Mac address flapping across wireless network
iniestha.aung
Frequent Visitor
Frequent Visitor
Hi  Everyone,
Greeting!
Can anyone suggest why mac address are flapping across wireless ?
Please see the logs below.
SW1(config)#do sho int des
Interface Status Protocol Description
Vl1 up up "Management_Vlan"
Fa0 admin down down
Gi1/0/1 up up AP
Gi1/0/2 up up AP
Gi1/0/3 up up AP
Gi1/0/4 up up AP
Gi1/0/5 up up AP
Gi1/0/6 up up AP
Gi1/0/7 up up AP
Gi1/0/8 up up AP
Gi1/0/9 up up AP
Gi1/0/10 up up AP
Gi1/0/11 up up AP
Gi1/0/12 up up AP
Gi1/0/13 down down AP
Gi1/0/14 down down AP
Gi1/0/15 down down AP
Gi1/0/16 down down AP
Gi1/0/17 down down AP
Gi1/0/18 down down AP
Gi1/0/19 down down AP
Gi1/0/20 down down AP
Gi1/0/21 down down AP
Gi1/0/22 down down AP
Gi1/0/23 down down AP
Gi1/0/24 up up Uplink-to-Router
Gi1/0/25 down down
Gi1/0/26 down down
Gi1/0/27 down down
Gi1/0/28 down down
SW1(config)#
001812: Mar 6 2022 08:58:40.476 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host a2ff.13c8.ebf3 in vlan 3 is flapping between port Gi1/0/7 and port Gi1/0/1
001813: Mar 6 2022 17:57:06.454 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host 1292.2d61.8fe2 in vlan 3 is flapping between port Gi1/0/12 and port Gi1/0/11
001814: Mar 6 2022 19:55:52.733 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host a2ff.13c8.ebf3 in vlan 3 is flapping between port Gi1/0/1 and port Gi1/0/12
001815: Mar 7 2022 07:31:28.838 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host ced2.42ed.b478 in vlan 3 is flapping between port Gi1/0/8 and port Gi1/0/7
001816: Mar 7 2022 17:02:19.607 SGT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/10, changed state to down
001817: Mar 7 2022 17:02:20.606 SGT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/10, changed state to down
001818: Mar 7 2022 17:02:28.964 SGT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/10, changed state to up
001819: Mar 7 2022 17:02:30.966 SGT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/10, changed state to up
001820: Mar 7 2022 17:03:30.976 SGT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/10, changed state to down
001821: Mar 7 2022 17:03:31.980 SGT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/10, changed state to down
001822: Mar 7 2022 17:03:34.660 SGT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/10, changed state to up
001823: Mar 7 2022 17:03:36.667 SGT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/10, changed state to up
001824: Mar 8 2022 07:35:25.972 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host ced2.42ed.b478 in vlan 3 is flapping between port Gi1/0/10 and port Gi1/0/8
001825: Mar 9 2022 08:18:17.522 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host 1292.2d61.8fe2 in vlan 3 is flapping between port Gi1/0/8 and port Gi1/0/7
001826: Mar 10 2022 07:34:06.339 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host a2ff.13c8.ebf3 in vlan 3 is flapping between port Gi1/0/5 and port Gi1/0/2
001827: Mar 10 2022 07:52:19.735 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host f60f.b045.6aae in vlan 3 is flapping between port Gi1/0/1 and port Gi1/0/3
001828: Mar 10 2022 13:16:55.107 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host a2ff.13c8.ebf3 in vlan 3 is flapping between port Gi1/0/3 and port Gi1/0/2
001829: Mar 10 2022 19:47:48.867 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host 16f2.7d12.b09c in vlan 3 is flapping between port Gi1/0/3 and port Gi1/0/4
001830: Mar 10 2022 23:41:38.960 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host 8a28.7f95.424a in vlan 3 is flapping between port Gi1/0/6 and port Gi1/0/5
001831: Mar 11 2022 18:16:45.883 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host a2ff.13c8.ebf3 in vlan 3 is flapping between port Gi1/0/12 and port Gi1/0/11
001832: Mar 12 2022 05:36:11.814 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host a2ff.13c8.ebf3 in vlan 3 is flapping between port Gi1/0/3 and port Gi1/0/4
001833: Mar 12 2022 07:28:36.370 SGT: %SW_MATM-4-MACFLAP_NOTIF: Host a2ff.13c8.ebf3 in vlan 3 is flapping between port Gi1/0/1 and port Gi1/0/2
001834: Mar 12 2022 12:48:45.334 SGT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to down
001835: Mar 12 2022 12:48:46.340 SGT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2, changed state to down
001836: Mar 12 2022 12:48:54.733 SGT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2, changed state to up
001837: Mar 12 2022 12:48:56.735 SGT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up
001838: Mar 12 2022 12:49:58.115 SGT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to down
SW1(config)# do sho ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(4)E7, RELEASE SOFTWARE (fc2
2 Accepted Solutions
Mark Elsen
        - These messages can usually be ignored. It happens when the client is roaming between access points.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mohsin Alam
This will be expected if the wireless user is roaming around and will lead to mac flap i.e. learning of MAC on different ports. You can create a logging discriminator to ignore this.
## Make sure to mark post as helpful, If it resolved your issue. ##
5 Replies 5
iniestha.aung
Frequent Visitor
Frequent Visitor
This is one of the port(AP) configuration .
SW1(config)#do sho run int g1/0/1
Building configuration...
Current configuration : 112 bytes
interface GigabitEthernet1/0/1
description AP
switchport trunk allowed vlan 1-3
switchport mode trunk
end
Mark Elsen
 M.
Thanks Marce for the answer .
Mohsin Alam
Thanks Mohsiala for the answer.
