Showing results forĀ
Search instead forĀ
Did you mean:Ā
MAC entries
iamtheone12345
Hi Guys,
How do i see a complete list of mac addresses for a particular switch.
I am aware that show mac-address-table shows the  the the mac addresses learned by the switcj.
also show interfaces command will list all the interfaces with mac addresses.But i have to look down the entire interface details to find out a particular mac address.
Is tehe any command which lists directly the mac addresses with respect to interfaces of a switch???
I am talking about interfaces that are assigned a particular mac addresss already.I am not manually assigning them a mac address.
I am using cisco packet tracer and show mac-address-table only shows me the address its learning dynamically.
Thanks.
Reza Sharifi
if you do a
sh mac address-table vlan 10
it will show you the MAC addresses in vlan 10 and also the interfaces belonging to it
also
sh mac address-table dynamic
show you all the macs and interfaces that have been learned dynamically
