09-01-2020 02:53 PM
Good afternoon everyone,
I'm rusty and I could be doing something wrong but I cannot figure this out =(. I have a setup of five switches
All of the switches can ping and ssh/telnet into the main switch. But when I put the mac-sticky command every port switchport port-security mac-address sticky.
It shows nothing when I do show mac-address table | in (insert last 4 of mac). I would really appreciate if if someone can tell me what I'm doing wrong.
09-01-2020 03:00 PM
Are you enabling on the Uplink port connected to Main Switch or Access port on each switch ?
can you post example of the port config :
have you enabled port security before adding sticky config
here is the configuration guide for reference :
09-02-2020 06:34 AM
I will try and get that and thank you for responding.
