Macro: Enable FastEthernet 1/0/1-10 if FastEthernet 1/0/48 is going down
Kai Onken
I would like to know, if it is possible to set the interface range FastEthernet 1/0/1-10 to "no shutdown" via marco, if Interface FastEthernet 1/0/48 changes state to down (e.g. Networkcable unplugged).
If it ist possilbe could you provide the macro here?
Kind regards
sleepyshark
Kai -
You absoultely can script items like this with Cisco devices - they are standard telnet/SSH.  However you have to take a few things into consideration.
1. The device is a switching/routing operating system, meaning it has limited adminsitrative tools; in your case, there is no way on the device to have it recognize if an interface went down and to executive a script.
2. What you're wanting to accomplish can easily be handled by some SNMP monitoring software and having that software run a script which logs into the device, and issues the appropriate commands.
The key to accomplishing what you want to do is the fact that it cannot be handled internally, but my be handled by a third-party device.
Sean Brown
http://www.sleepyshark.com
(Rate me, if i'm helpful)
Hi Sean,
Thank you for your quit answer. Please tell if I'm wrong. The the Switch can recognize, if an interface changes his state to up. After this a macro will be executed.
Like this for example
configure terminal
         macro name changevlan
         switchport access vlan $access
         !=== Create macro
         interface FastEthernet 0/1
         macro apply changevlan $access 100
         !=== Apply macro - variable = 100 - put interface in vlan 100
So, if I understood you correctly, the switch can not execute an macro on port down only on port up like in my sample?
Kind Regard
I got a few steps closer to my target, currently I'm trying this
function MyFunction () {
  if [[ $LINKUP -eq NO ]]; then
     interface  $INTERFACE
       no shutdown
     exit
  fi
But now I'v to setup, that $LINKUP tracks the port state of GigabitEthernet 0/48 and $INTERFACE hast to be raplaced with interface range gigabitEthernet 0/1-10
