Macsec between 9500 and 3560cx
garyromine
I have a network that is building built out and I cannot get macsec to work between a 9500 and a 3850cx. It works between the 9500 and 9300s without a problem. All I am doing is switch-to-switch macsec at this time. I am also new to implementing macsec so I am not sure if I have it configured properly between the two platforms.
9500 (C9500-48Y4C)
Cisco IOS XE Software, Version 17.03.04
  License                 Entitlement Tag               Count Status
  network-advantage       (C9500 Network Advantage)         2 IN USE
  dna-advantage           (C9500 48Y4C DNA Advantage)       2 IN USE
3560CX (3560CX-12PD-S)
Cisco IOS 15.2(7)E4
License Name                  Type          Period left
ipservices                    PermanentRightLife time
ipbase                        Permanent     0  minute  0  second
dna-advantage                 Subscription  CSSM Managed
This is the config side of the 9500
key chain mka-keychain macsec
key 01
lifetime 00:00:00 1 Jan 1993 infinite
cryptographic-algorithm aes-256-cmac
key-string <OMITTED>
interface Config
 macsec network-link
 mka pre-shared-key key-chain mka-keychain
 switchport trunk native vlan 101
 switchport trunk allowed vlan 101
 switchport mode trunk
 channel-group 2 mode desirable
spanning-tree link-type point-to-point
spanning-tree portfast network
udld port aggressive
auto qos trust
interface Port-channel2
interface Vlan101
 ip address XX.XX.XX.XX 255.255.255.254
 ip authentication mode eigrp 100 md5
 ip authentication key-chain eigrp 100 EIGRP
 ip pim sparse-dense-mode
This is the config side of the 3560cx
key 01
interface Config
 srr-queue bandwidth share 1 30 35 5
 priority-queue out
 macsec network-link
 mls qos trust cos
 auto qos trust
 channel-group 1 mode desirable
interface Port-channel1
interface Vlan101
If I remove “macsec network-link” from the 9500 interface link everything comes up and works properly. I have also noticed that on the 9500 the sh macsec inter on the 9500 shows disabled but this seems to be consistent with the other switches until macsec is established. The only other thing I see and I don’t know how to address is when I run the sh mka keychains the latest CKN is different.
On the 9500 it looks like this:
MKA PSK Keychain(s) Summary...
Keychain         Latest CKN                                                       Interface(s)
Name             Latest CAK                                                       Applied
mka-keychain     01                                                               Twe2/0/46      Twe2/0/45
                 <HIDDEN>                                                         Twe2/0/43      Twe2/0/42
        Twe2/0/41      Twe1/0/46
        Twe1/0/45      Twe1/0/43
        Twe1/0/42      Twe1/0/41
                 <HIDDEN>
On the 3560cx it looks like this:
mka-keychain     0100000000000000000000000000000000000000000000000000000000000000 Te1/0/2        Te1/0/1
                 <HIDDEN>
To me that looks like the 3560cx is adding trailing zero but I don’t know if that is transmitted between to two switches in macsec negotiations.
I also get “%SPANTREE-2-BRIDGE_ASSURANCE_BLOCK:” in the log. I only have one 10GB fiber connection between the two switches.
Any ideas what I have configured wrong?
marce1000
             - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs92023
 M.
marce1000
 M.
Thanks for the help! I was using leading zeros, not trailing zeros. Also to note for anyone using this I have to create a key chain for the 9500 to 9300 series switches and another key chain for 9500 to 3560cx.
Again, thanks for the quick help!
