IE-4000,Does Cisco's Industrial Switch IE series support netflow?
zrich
Hi , all.
It is possible to configure the IOS NetFlow in a IE4000?
While I was using this switch, I met some problems. After I started Netflow on the switch, the switch did not output the flow. The output is shown below.
lab640#show ip cache verbose flow
IP packet size distribution (0 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 278544 bytes
0 active, 4096 inactive, 0 added
0 ager polls, 0 flow alloc failures
Active flows timeout in 30 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 33608 bytes
0 active, 1024 inactive, 0 added, 0 added to flow
0 alloc failures, 0 force free
1 chunk, 1 chunk added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
SrcIf SrcIPaddress DstIf DstIPaddress Pr TOS Flgs Pkts
Port Msk AS Port Msk AS NextHop B/Pk Active
Giuseppe Larosa
Hello @zrich ,
according to table 9 of the following datasheet
https://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-4000-series-switches/datasheet-c78-733058.html
IE 4000 should support Flexible Netflow with IP services License
Check the license you have it can be a license issue. If you have the right license it would become a configuration issue
Hope to help
Giuseppe
Hi, dear Giuseppe, thanks, i've actived the license:
lab640#show license
Index 1 Feature: ipservices
Period left: 8 weeks 4 days
License Type: Evaluation
License State: Active, in Use, EULA accepted
License Priority: High
License Count: Non-Counted
Follow the flexible-netflow manual command, I can only use a portion of the flexbie-netflow command, like configure the monitor and expoter or something, but i can't configure the interface as the netflow interface, for example:
Device(config)# interface GigabitEthernet 1/1/2
Device(config-if)# ip flow monitor FLOW-MONITOR-1 input
it shows invalid command,and the '^'symbol appears before the "flow" , like this: "^flow"
by the way, i also checked the cisco CFN Cisco Feature Navigator to get the function which IE4000 can supported, it shown something but not included NetFlow, Is that a problem? please.
