MACsec should-secure 3850 interfaces
DB1991
Does anybody know how to configure the should-secure option on interfaces for 3850's?
I've got MACsec working between two 3850s, but I don't have any option to enable should-secure on the interface. Do the 3850's not support this?
I believe the command should be - #(config-if)"Macsec access-control should-secure" but I have no option for this.
DanielP211
Hello!
The should-secure option is for WAN macsec and it allows unencrypted packets from the physical interface or subinterfaces to be transmitted or received.
What are you trying to achive?
BR
****Kindly rate all useful posts*****
