%PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 1's power stack lost redundancy and is now operating in power sharing mode
Ibrahim Jamil
Level 6
Level 6
Hello freinds
the below complain Anoying me  , how to disable it  , i did no logging consol  | no loggin on but still appears , looks this kind of Missing PS has high built-in identity
SWT(config)#do sh env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is NOT INITIALIZED
FAN PS-2 is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 19 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  UNKNOWN             unknown     No Input Power  Bad      N/A      0/0
1B  C3KX-PWR-1100WAC    LIT151706RG OK              Good     Good     1100/0
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
thanks
Ben Walters
Level 4
Level 4
If you do sho run all and look at the section with logging commands there may be more options that you might be able to turn off to disable those error messages.
Also check if you have stack-power commands in your running config, if you have configured stack power it might be another reason for these messages.
Hello
If you want to negate logging messages it can be as easy of disabling monitoring or decreasing the buffered level. - Can you post the output from - Show logging
You also have an option of applying a logging discriminator but please post the output for the logging first.
res
Paul
Kind Regards
Paul
woocash_m
From your output, you have a stand-alone switch.
Most likely you have the below config on the switch:
stack-power stack PowerStack-1
mode redundant
stack-power switch 1
stack PowerStack-1
To stop logs showing up this should be configured as below:
mode power-shared
standalone
Lucas
DanielP211
Hello!
You can setup an logging discriminator:
logging discriminator STACK msg-body drops PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS
logging buffered discriminator STACK 200000
BR
****Kindly rate all useful posts*****
