02-17-2007 05:47 AM - edited 03-05-2019 02:25 PM
Hi guys :)
I have configured and delivered to customer a network system consists of five 4506 switches (with 24 port MTRJ fiber optic line card and gigabit fiber LC SFPmodule).
Customer is asking me protective maintenance documentation for 4506 switches and it's modules.
I couldnt find such documents in cisco.com.
As far as I know; unlike computers and other electronic devices, network active devices are designed to work for years without any intervention.
But I dont want to mislead my customer. Do you guys have something to say about protective maintenance for above mentioned devices?
tx in advance for help
02-18-2007 01:52 AM
Hi Alfonzo
Generally speaking you are right in what you say. However i would add a couple of things
1) Bugs in the IOS / CatOS will require intervention on the switches. So they would need to check the security updates.
2) Based on past experience i would also recommend maintencance windows for the switches to give them a clean reboot. We have been hit in the past with rebooting modular switches that have been up for years that then have module failures on the reboot. Better to find this out in a regular maintenance window than when you really need it ie. a complete power failure.
Jon
02-18-2007 04:22 AM
tx Jon.
