major issue with 6509 blade, please help
carl_townshend
Hi all
tonight we suffered a big outage on the network, the fix was to reload the module 3 on the 6509 switch, we had these errors on the log
%CONST_DIAG-SW1_SP-3-HM_PORT_TEST_FAIL: Switch 1 Module 3 TestUnusedPortLoopback Port(s)[24,46] failed. System operation continues.
in the end, we reloaded the card and it was all ok.
is there anything I can do to check the card / or any deeper logs?
would that error cause the card to crash?
cheers
Carl
Leo Laohoo
Hey Carl,
Normally a "loopback" failure is a component failure.
Keep an eye on it.  If it acts up like this again, RMA the card.
On a 6500, an operator can initiate a Generic On-Line Diagnostic (GOLD) using the command "diagnostic".  Take note that there is a disruptive and non-disruptive test.
