Making a routed switch virutal interface the default SVI
Joshua Engels
I am having an issue where I am adding a catalyst switch to my ACS server for AAA authentication.
I have a catalyst with the following:
inteface vlan 174
ip address 192.168.174.1
interface vlan 199
ip address 192.168.199.1
When I setup the switch in the ACS, the ACS rejects it because it sees the traffic coming from a different SVI 2.  I would like to set it up on SVI 174.  My question is, how do I make the traffic source out of SVI 174?
Josh
Nagaraja Thanthry
Can you try "ip tacacs source-interface "vlan id"" and see if that helps?
NT
Nagaraja Thanthry
NT
That worked.  Thanks a lot!
