Management interface configuration with ACL on Catalyst Switch
muhsintt9
Hi Everyone,
I need some help with a catalyst 9300 switch configuration
I have set up a switch with the following amongst others:
Enable login and local login account
Standard access-list permitting a list of subnets to access the VTY lines
Access list applied on all VTY lines and VTY set to accept SSH
An IP address on management interface (g0/0 for this switch)
Default gateway.
Crypto key generated
The switch needs to be accessed via its management interface
Issue:
I am unable to access my catalyst switch through its management interface.
What has been tried:
Pinging the management interface – works
SSH doesn’t work (connection refused) with allowed subnets unless the access list is removed from the VTY lines.
Thoughts:
May have something to do with VRF on the management interface????
Can anyone help me with what is missing to allow SSH through the management interface when the access-list is applied?
Thank you
Reza Sharifi
Can you post the output of "sh run"?
