07-11-2013 10:19 AM - edited 03-07-2019 02:21 PM
Hello Guys,
We have a 2350 switch with managment vlan and now we are deploying a management switch (2350) to manage all the devices with this. So i have to get ride of that management vlan and have a physical management port with the same IP (as in mgmt vlan). Everything shows up when i shut down the mgmgt vlan and open the mgmt physical port, but I am not able to login via ssh or telnet using the physical mgmt port IP. Can you guys please bail me out.
Thanks.
07-11-2013 10:52 AM
So you are using a new 2350 to manage the rest of your switches out of band?
Can you post the config from the managment switch?
07-11-2013 11:11 AM
Hello Reza,
Thank you for the reply. I will review the senario for you. We have a L3 6509 (vlan 308 configured) and to this we have 2350 (we call TOR) with mgmt vlan with IP from VLAN 308.
Now we are deploying a new 2350 (mgmt swt) to manage all the device connected to 6509. So the mgmt swt is connected to 6509 and TOR. The link between 6509 and mgmt swt is good, i can even login into the mgmt swt remotely. but there is a problem with TOR, the TOR was having mgmt int vlan with IP again from vlan 308, and i wanted this IP to be on the physical mgmt port of the TOR and then remove the mgmt vlan completely. Please find below the config of the mgmt swt:
Building configuration...
Current configuration : 9628 bytes
version 12.2
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
service linenumber
hostname
boot-start-marker
boot-end-marker
logging buffered 65535 informational
no logging console
logging monitor informational
no aaa new-model
clock timezone utc 0
system mtu routing 1500
vtp domain b11-23m-int-1-1
vtp mode transparent
ip subnet-zero
no ip source-route
no ip icmp rate-limit unreachable DF
ip domain-list ntwk.msn.net
no ip domain-lookup
ip domain-name ntwk.msn.net
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery interval 60
port-channel load-balance src-dst-ip
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 99
name DUMMY_VLAN
vlan 308
ip ftp source-interface FastEthernet0
ip tftp source-interface FastEthernet0
ip ssh time-out 30
description LUSRED011C6N01:Gi3/40 MGMT VLAN 308
ip address 10.195.151.18 255.255.255.128
no ip route-cache
interface GigabitEthernet0/1
description b11-23x-int-1-01 Fa0
switchport access vlan 308
switchport mode access
no logging event link-status
load-interval 30
mls qos trust dscp
flowcontrol receive on
interface GigabitEthernet0/2
description b11-23x-int-1-02 Fa0
load-interval 30
mls qos trust dscp
spanning-tree guard root
interface GigabitEthernet0/3
description b11-23x-int-1-03 Fa0
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/4
description b11-23x-int-1-04 Fa0
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/5
description b11-23x-int-1-05 Fa0
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/6
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/7
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/8
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/9
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/10
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/11
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/12
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/13
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/14
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/15
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/16
load-interval 30
mls qos trust dscp
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface TenGigabitEthernet0/1
interface TenGigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
ip http server
ip http secure-server
ip tacacs source-interface FastEthernet0
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
07-11-2013 11:47 AM
Are you planning to put an SVI on the mgmt switch, because in your config I don't see that.
config t
interface valn 308
ip address xx.xxx.xxx.xxx
If this is the case you then need a /30 between the switch and the 6500 and default route on the mgmt switch.
If you are planning to extend vlan 308 all the way to the 6500 and use the mgmt switch as a layer-2 device only, then you need to create a trunk link between the mgmt switch and the 6500 and create the SVI for vlan 308 on the 6500. You would also need to a default gateway on the mgmt switch pointing to the 6500 SVI.
07-11-2013 12:33 PM
Reza,
We would like to get ride of the SVI as many as possible. Some of the TOR are having a separate mgmt port available so i would like to use that as mgmt for the TOR. The vlan is extended already.
On the TOR:
it was
int vlan 308
ip address 10.10.10.1 x.x.x.x
i want to make
int fa0
to work and then delete the svi vlan 308 on TOR.
THE VLAN whole subnet was created on 6500 and extended to TOR. ip default is also pointed to 6500 in other TOR I have 3 TOR.
Thank you.
07-11-2013 12:46 PM
int vlan 308
i want to make
int fa0
Correct, I understand. You are trying to go from an inband mgmt to an out of band. You don't need any default gateway on the TORs since you are using the management interface. That is just a host port with an IP just like a PC or printer etc...
You only need a default gateway on the management switch and not the TORs.
07-11-2013 01:27 PM
ok I have configured ip default on mgmt swt, and i have removed the ip default gateway on TOR.
not working...
If i am using the same IP (from mgmt vlan on physical mgmt port) there wont be any routing issue right.
Thank you Reza.
07-11-2013 07:02 PM
No, your TOR switches are treated as hosts. Think of them being just like PC or any other end device with an IP address.
Did you create a trunk connection between the management switch and the 6500?
Can you post the config for SVI for vlan 308 from the 6500 and also the trunk link between the 6500 and the management switch?
