Management VLAN Migration from /27 to /25
Christian.R
Hi Guys
Im planning a migration of a management Vlan.
Could you please review the following idea:
Is it possible to configure a secondary IP address on the mgmt Vlan interface (Access-Switch).
->with no connection loss<-
Then configure the new default gateway on the access-Switch.
->now connections loss<-
Then change the Subinterface IP address on the router to the new IP range.
->connection restored<-
(Via secondary IP on the Access-Switch / new Subnet)
Then clean up the Access-Switch mgmt vlan interface.
->delete old ip statement, move the same ip address from secondary to "primary", then delete the secondary statement
Thanks in advance for your help
Greetz Chris
Mark Malone
sounds ok
creating a secondary does not cause any issue , will not bounce an interface
"move the same ip address from secondary to "primary", then delete the secondary statement"
You just remove the secondary part of the command to make it primary , it wont allow 2 of the same subnet under the interface even of secondary is configured
Mark Malone
sounds ok
Hi Mark
Thanks for your input.
Chris
i did verify it in a test environment
example:
Interface Vlan 10
description mgmt vlan
ip address 192.0.0.1 255.255.255.0
ip address 192.0.0.2 255.255.255.0 secondary
as soon as you type (in interface vlan 10)
it will become the "primary" IP and the secondary statement will be deleted (since its the same IP address)
Regards Chris
ah grand :)
