MANET DLEP and VMI
eugen.reznik1
I am trying to configure 5921 router to work with dlep simulator (https://sourceforge.net/projects/dleptools/).
I have two routers 5921 and two dlep simulators on lan.
Using dlep 1.0 version in router.
I follow instructions from Software Configuration Guide for Cisco IOS Release 15.3(4)T.
I get to the point where router can see dlep neighbor and this neighbor appears in vmi neighbor list.
But ospfv3 process doesn't accept dlep neighbor as ospfv3 neighbor.
I can clearly see that ospf Hello messages are issued by vmi interface.
On the other hand it looks like ospf configured on vmi doesn't receive any Hello from neighbor.
I also can not ping ipv6 global address of neighbor vmi interface.
Can anyone give me some example of actually working configuration and short explanation what is wrong with mine?
Thanks in advance.
This is my configuration of one of the routers.
 ______________________________________________________________________________________________________________
Current configuration : 4205 bytes
! Last configuration change at 15:50:16 IST Fri Apr 1 2016
version 15.5
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ipv6 unicast-routing
ipv6 cef
redundancy
no cdp run
interface Ethernet0/0
ip address 10.0.1.2 255.255.0.0
no ip proxy-arp
ip dlep vtemplate 1 port 5555
duplex auto
speed auto
ipv6 enable
no keepalive
interface Ethernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Ethernet0/2
ip address dhcp
duplex auto
speed auto
interface Ethernet0/3
no ip address
shutdown
interface Ethernet1/0
no ip address
shutdown
interface Ethernet1/1
no ip address
shutdown
interface Ethernet1/2
no ip address
shutdown
interface Ethernet1/3
no ip address
shutdown
interface Virtual-Template1
ip unnumbered Ethernet0/0
ipv6 enable
no keepalive
interface vmi1
ipv6 address FE80::20C:29FF:FE29:2AF9 link-local
ipv6 address 2001:4860:4860::2/64
ipv6 enable
ospfv3 6 network manet
ospfv3 6 ipv6 area 0
physical-interface Ethernet0/0
router ospfv3 6
router-id 1.1.1.2
address-family ipv6 unicast
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input none
end
0 Replies 0
