Manual binding, DHCP 3850
Hello, I have some cisco 3850 with DHCP for my AP.
I need to supervise my AP, so I try to assign the same IP address per mac-address.
So i follow this link: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dhcp/configuration/xe-3se/3850/dhcp-xe-3se-3850-book/config-dhcp-server.html#GUID-68D87544-7C6F-48C9-9DFE-56F5B7E4A89D
But in this solution, i must create a pool DHCP per AP... Is it possible to create just one DHCP pool for all my AP ? Thanks in advance.
Aaron Harrison
Through config, you have to create a pool per device.
The other option is to create a text file listing the bindings - as detailed here: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dhcp/configuration/xe-3se/3850/dhcp-xe-3se-3850-book/config-dhcp-server.html#GUID-BCEB43D4-8C44-4C86-BBAA-6B977196D35C
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
it's working, i follow the post 9
https://learningnetwork.cisco.com/thread/24891
Thanks.
