manually pruning of vlan and vtp
sarahr202
Level 5
Level 5
hi every body!
Is it possible to prune vlan manually on interface by using " switchport trunk pruning vlan " command, while vtp is not enabled?
thanks!
gpulos
Level 8
Level 8
You cannot 'prune' with out VTP being enabled.
Pruning requires VTP operation as it is a function of VTP.
Please see the following link for more info:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a0080094c52.shtml#vtp_pruning
gpulos
Level 8
Level 8
thanks for your reply.
you can use the 'switchport trunk allowed vlan' command to get the same desired effect, if vtp is not enabled.
Sara:
There is a bit of contradiction in your question. Pruning "manually" does not mean utilizing that command. That command is utilized within the framework of VTP, as was pointed out.
You can, however, prune manually, as you ask, by using the switchport trunk allowed vlan [vlan list] command under the trunk interface configuration. You simply list the vlans that you want to allow, all others will be blocked by default. In the absence of this command, all vlans will be allowed.
In CatOS switches, you can use the clear trunk command as follows:
Switch> (enable) clear trunk 1/1 2-9,12,14-1005
Removing Vlan(s) 2-9,12,14-1005 from allowed list. Port 1/1 allowed vlans modified to 1,10,11,13.
Victor
