Mass interface configuration
peter.conings
Level 2
Level 2
With Cisco IOS is there a similar command to 'mass' configure settings for interfaces.
eg in CatOs you put:Set vlan 1 2/1-10 so the command has impact on ports 1 to 10. Is there a similar command in IOS to put settings for more interfaces in one command?
5 Replies 5
Jon Marshall
Hi Peter
switch(config)# interface range fa2/1 - 10
switch(config-if-range)# switchport access vlan 1
Jon
Hi Peter,
In addition to Jon's post even if your port range is discontigous you can configure them at one go
Switch(config)#int range gig1/0/2,gig1/0/8,gig1/0/24
Switch(config-if-range)#switchport mode access
Switch(config-if-range)#switchport access vlan 1
Ankur
*Pls rate all helpfull post
jdarrish
Community Member
I think you're looking for the 'range' command after 'interface':
For instance to set ports 2/1 through 10 to vlan 55, run the following
switch(config)# interface range fa 2/1 - 10
switch(config-if-range)# switchport mode access
switch(config-if-range)# switchport access vlan 55
Thanks guys for quick replies. Saves me a lot of time 🙂
thinicemike
Frequent Visitor
Frequent Visitor
DISCLAIMER: Super Late reply
switch#configure terminal
switch(config)# interface range gi1/0/1 - 48
switch(config-if-range)#shut
