Master stack switch replacement procedure
escobilloe
Community Member
Hi Gents,
I recently found out that obe of the stack port on my 3750x is faulty thus failig the ring status of my 2x3750x. With the troubkeshooting that i did, i finaly concluded that the problem is on the port of the master switch. See status below.
Switch# Port 1 Port 2 Port 1 Port 2
1 Ok Down 2 None
2 Down Ok None 1
Now i'm a bit hesitant in doing the ptocedure that i have in mind. If sone please connfirm if my procedure is correct. Take note that this is a live environment.
-turn off switch1(master)
-switch 2 shoould take over as master.
-connect the new switch (rna'd switch to replace the master)
-reload the entire stack and switch one should take over the mastet state and get the config from switcch 2.
Thats what i have in mind, if someone could please verify if i'm right?. Thanks guys!
13 Replies 13
Reza Sharifi
Richard Primm
Hi Erwin,
To add a switch, as a master, to a stack, complete these steps:
Note: Make sure the switch you add into the stack has the same IOS version as the switches in the stack. Refer to Catalyst 3750 Software Upgrade in a Stack Configuration with Use of the Command-Line Interface to upgrade the IOS in a catalyst 3750 switch.
Issue the show switch command.to get the priority value of the members of the stack.
3750-Stk>show switch
                                               Current
Switch#  Role      Mac Address     Priority     State
1       Slave     0016.4748.dc80     1         Ready
*2       Master    0016.9d59.db00     5         Ready
Change the priority value of the switch to be added to a value greater than the highest priority of the stack. In the illustration, the priority value has to be a value of more than "5.".
switch stack-member-number priority new-priority-value
Make sure that the stack is fully connected so that, when you connect the new switch, the stack will be at least in half connectivity, and do not partition.
With the new switch powered on, connect the StackWise ports of the switch to the stack.
The election for the stack master occurs, and the new switch will be elected as the master since it has the highest priority value.
The members of the previous stack will reboot themselves to join the new stack. After all the members come up, issue the command show switch to verify stack membership.
Reference:
Tips to Add a Switch as a Master to the Stack
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#stack4
escobilloe
Community Member
Hi!
I will be replacing a failty master switchand will no add a new one. I believe the procedures mentioned above is for asding a new master switch.
If i powered off the existing master, will the slave take over?
And when i connect the new switch to the stack, will it take over as a mastet and as a switch 1?
Will it download the config from switch 2?
Yes and this is what you want.
No it won't because you did not specify the switch priority and you did not reboot the stack.
If you want the new switch to take over, configure the switch priority (after the new switch has joined the stack) and reboot the stack.
escobilloe
Community Member
Hi Leo,
Thanks!
If I plugged in the new switch, will it be switch number 1? I just dont want to mess up the ibterface configs and number.
And will it not ibherit the current priority set to switch 1?
Yes.
Yes.
escobilloe
Community Member
Thanks mate!
Here's the show switch stack-ports summary output incase you noticed sonething other than a physical problem.
witch01#sh switch stack-ports summary
Switch#/ Stack Neighbor Cable Link Link Sync # In
Port# Port Length OK Active OK Changes Loopback
Status To LinkOK
1/1 OK 2 50 cm Yes Yes Yes 1 No
1/2 Down None 50 cm No No No 5 No
2/1 Down None 50 cm No No Yes 5 No
2/2 OK 1 50 cm Yes Yes Yes 1 No
switch01#
I just noticed that 'sync ok' is set to 'yes' on the switch 2 port 1
Leo Laohoo
Post "sh switch detail" & "sh version".
Sent from Cisco Technical Support Nintendo App
escobilloe
Community Member
witch#sh switch detail
Switch/Stack Mac Address : fc99.47c0.8500
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master fc99.47c0.8500 15 1 Ready
2 Member fc99.47c3.5880 14 1 Ready
Stack Port Status Neighbors
1 Ok Down 2 None
2 Down Ok None 1
switch#sh swi
switch#sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:40 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
switch uptime is 19 weeks, 4 days, 4 hours, 26 minutes
System restarted at 14:01:46 AEST Thu May 30 2013
System image file is "flash:/c3750e-universalk9-mz.122-55.SE3/c3750e-universalk9-mz.122-55.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3750X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Last reset from power-on
4 Virtual Ethernet interfaces
1 FastEthernet interface
56 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Switch Ports Model SW Version SW Image
* 1 30 WS-C3750X-24 12.2(55)SE3 C3750E-UNIVERSALK9-M
2 30 WS-C3750X-24 12.2(55)SE3 C3750E-UNIVERSALK9-M
Output looks good.  The only issue I can see is that your stack is only connected with only ONE stacking cable.
This means you don't have redundancy and your stacking "ring" is operating at half speed.
escobilloe
Community Member
Thanks! So by the output can we conclude that its a hardware fault?
Not a hardware fault.  Someone possibly did not cable up the 2nd cable properly.
escobilloe
Community Member
We already replaced the 2ndcable with a new one as advise by cusco tac hut ti ni avail. Now we are replacing the switch as it might be the stack port that is faulty.
