match mpls packets for qos on a nexus 5000
JAN HASSE
we would like to match mpls packets via an ACL on nexus 5k to send them into a certain QoS-group. Incoming interface is eth 1/8.
Is this possible with the following configuration?
I ask, because in the ACL we have permt IP any any but MPLS tagged frames are not IP??
ip access-list ACL_WAN-VLANS
  10 permit ip any any
class-map type qos match-any CMAP_WAN-VLANS
  description match via acl all vlans with WAN traffic
  match access-group name ACL_WAN-VLANS
policy-map type qos PMAP_IN_MARK_WAN
  class CMAP_WAN-VLANS
    set qos-group 4
interface Ethernet1/8
  service-policy type qos input PMAP_IN_MARK_WAN
Do we have the mpls packets then in QoS group 4? We would like then to separate the bandwith later on the outgoing interface (config not shown here...)
Thx
  Jan
rsimoni
Hi Jan,
mpls is considered non-ip traffic, so your ACL won't match labelled packets.
N5k does not support MPLS by the way.
You need to move MPLS QoS policy on other devices.
Riccardo
JAN HASSE
Hi Riccardo,
ok, I understand that the ACL will not match.
I am also aware that the N5k cannot speak mpls, but we only have this device inbetween two MPLS device (a nexus 7k and a cat6500). This should be possible? The "non IP traffic" (=mpls tagged traffic) should be forwarded if the mtu is high enough? And the traffic is forwarded in the class class default (or qos-group 0)?
Or is "non ip traffic" totally dropped by a n5k?
thx
Jan
Hi Jan,
it is forwarded as any other L2 traffic (if received on L2 switchport of course) if yes the MTU check is passed.
Riccardo
krun_shah
Although I have not done or tried it my self, you can define a MAC acl matching ethertype of MPLS then use it within class map.
NX5K01(config-mac-acl)# permit any any ?
  <0x0-0xffff>  MAC protocol number
  aarp          Appletalk AARP
  appletalk     Appletalk
  cos           CoS value
  decnet-iv     DECnet Phase IV
  diagnostic    DEC Diagnostic Protocol
  etype-6000    Ethertype 0x6000
  etype-8042    Ethertype 0x8042
  ip            IP (Internet Protocol V4)
  lat           DEC LAT
  lavc-sca      DEC LAVC,SCA
  mop-console   DEC MOP Remote console
  mop-dump      DEC MOP dump
  vines-echo    VINES Echo
  vlan          VLAN number
NX5K01(config-cmap-qos)# match ?
  access-group  Access group
  cos           IEEE 802.1Q class of service
  dscp          DSCP in IP(v4) and IPv6 packets
  ip            IP
  precedence    Precedence in IP(v4) and IPv6 packets
  protocol      Protocol
   The ethertype value 8847 hex is used to indicate that a frame is carrying an MPLS unicast packet.
   The ethertype value 8848 hex is used to indicate that a frame is carrying an MPLS multicast packet.
