Maximum nodes in VLAN?
MJonkers
Does someone know the maximum numbers of nodes that are allowed in a vlan according to cisco? Are the white papers?
The maximum size of the broadcast domain.
thx,
Marc
This might help you with something....
http://www.groupstudy.com/archives/cisco/199904/msg00896.html
Let some experts look into this issue..
aijaz802
I read somewhere that hosts per vlan should be like this...
1000 for "well behaved IP" -- hosts that just do ARPs, DHCP, etc. but no broadcast applications
500 for general IP with rational broadcast/multicast applications
200-500 for Apple, DECnet, CLNP -- assuming that hosts on the network
200 for NetBEUI
*aijaz*
Rate it if it helps..!!!
Is there somewhere a document which I can read?
thx,
marc
