Maximum number of ports in etherchannel
grapevine
Can you please let me know the maximum number of ports that could be bundled in etherchannel using LACP and also PAgP?
What is the difference between etherchannel and portchannel?
5 Replies 5
Mark Malone
8 for pagp and 4 for lacp , no difference etherchannel is portchannel
http://www.cisco.com/c/en/us/td/docs/ios/12_2sb/feature/guide/gigeth.html
http://www.cisco.com/c/en/us/support/docs/lan-switching/etherchannel/12023-4.html
Can you please let me know what is a layer 3 etherchannel called?
its called a layer 3 etherchannel
An etherchannel can be created with a maximum of 8 ports with an additional 8 backup ports.
Mark,
Are you sure the document you referenced that states 4 maximum ports for lacp is accurate?  I have not heard that restriction before and there are other documentation that states lacp supports 8 ports.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/CLIConfigurationGuide/EtherChannel.html#47157
Understanding LACP
LACP allows you to configure up to 8 interfaces into a port channel.
Never had more than 4 in 1 etherchannel so i cant say from experience would have to check but from what your saying i checked again and yes theres other docs saying that you can have 8 , that could be just specific to that version of IOS i didnt check against chasis just checked maximum allowed ports specific for LACP and that came up
