Maximum Throughput of Cisco 4948
Does anybody know the Maximum Throuput of a Csico 4948 using its Layer 3 capability? Is it 72mpps for Cisco 4948 and 102 mpps for Cisco 4948 10 Gigabitethernet?
Bryan
Reza Sharifi
it is 72m PPS.
from the data sheet:
The Cisco Catalyst 4948 delivers wire-speed  throughput with low latency for data-intensive applications, using a  96-Gbps switching fabric with a forwarding rate of 72 million packets  per second (mpps) in hardware for Layer 2 to 4 traffic. Switching  performance remains high regardless of the number of route entries or  Layer 3 and 4 services enabled. Hardware-based Cisco Express Forwarding  routing architecture enables increased scalability and performance.
Here is more info:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/product_data_sheet0900aecd8017a72e.html
ALIAOF_
Level 6
Level 6
Here is the link that shows a side by side comparison:
http://www.cisco.com/en/US/products/ps6021/prod_models_comparison.html
