md5sum & sha512sum verification on Nexus switch running with 9.3.11
Yuvi1983
Hi All,
I am having the issues while verifying the md5sum & sha512sum on the Nexus switch C93108TC-EX  running with 9.3.11
sw01# show file bootflash:nxos64-cs.10.3.6.M.bin md5sum
Error: /bootflash/nxos64-cs.10.3.6.M.bin: Value too large for defined data type
Also the "verify /md5 bootflash:nxos64-cs.10.3.6.M.bin" command deprecated .
Any idea how i can validate the file? file sums?
Thanks & Best Regards
Yuvaraj Karvekar
Enes Simnica
hello G.
For Nexus switches running NX-OS 9.3.x, the recommended method to verify file integrity is to use the built in file verification command: show file bootflash:nxos64-cs.10.3.6.M.bin verify,
the other alternative is using the linux shell: run bas
cd /bootflash
sha512sum nxos64-cs.10.3.6.M.bin
md5sum nxos64-cs.10.3.6.M.bin
ex
so yeah for sure the error u're encountering usually occurs with very large files (over 2GB) due to 32-bit integer limitations. Additionally, Cisco has deprecated the older verify /md5 command in newer NX-OS versions. It's always recommended to cross-check the generated hashes with the official checksums provided on Cisco's download page.
hope it helps G
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
MarianSK
Hi, we have the same issue, looks like a bug -> https://bst.cisco.com/quickview/bug/CSCwf32297
