ME-3600X vrrp configuration
I have found the HSRP configuration example in Cisco Metro Ethernet Switch ME-3600x/ME-3800x but unable to find the VRRP configuration exmaple in Configuration guide as well in Command Reference Guide.
I am using the IOS version
ME-3600: S360XVK9T-12252EY and ME-3400: S340XBT-12253SE
command reference guide:
http://www.cisco.com/en/US/docs/switches/metro/me3600x_3800x/software/release/12.2_52_ey/command/reference/3800x3600xcr.html
configuration guide:
http://www.cisco.com/en/US/docs/switches/metro/me3600x_3800x/software/release/12.2_52_ey/configuration/guide/3800x3600xscg.html
Kindly confirm either these switches support vrrp commands or not? If yes, kindly share configuration example.
kindly help
hi,
i know its not exactly your ios version and also just a generall manual, but maybe it still helps.
http://www.cisco.com/en/US/docs/ios/12_0st/12_0st18/feature/guide/st_vrrpx.html
regards,
florian
Amit Singh
Hi Shaikh,
Just checked it on the Cisco Feature Navigator. The IOS listed for ME3600 supports VRRP. However ME3400 does not support VRRP.
Please see the attached screen shots.
Cheers,
-amit singh
