ME-3800X-24FS-M
ruslank
I got on ME-3800X-24FS-M some strange messages and can't find any documents what is mean:
May  2 2011 17:18:27.552 EET: platform assert failure: 0: ../src-nile/src-asic-nile/nile_adjmgr.c: 6573: adjmgr_l3_switch_nh_to_ucast
May  2 2011 17:18:27.552 EET: -Traceback= 422970 53D924 D93EBC B402A0 B36C60 41E524 420794 B33F14 B35804 DC8EA4 DBF92C
May  2 2011 22:07:11.352 EET: platform assert failure: 0: ../src-nile/src-asic-nile/nile_adjmgr.c: 6509: adjmgr_l3_switch_nh_to_flood
May  2 2011 22:07:11.352 EET: -Traceback= 422970 53DE3C D93F58 B40910 B3745C 421C40 4222E0 DC8EA4 DBF92C
Installed software:
Cisco IOS Software, ME380x Software (ME380x-UNIVERSAL-M), Version 12.2(52)EY1, RELEASE SOFTWARE (fc1)
ROM: Bootstrap program is WHALES boot loader
BOOTLDR: ME380x Boot Loader (ME380X-HBOOT-M) Version 12.2(52r)EY2, RELEASE SOFTWARE (fc1)
3 Accepted Solutions
garhall
After decoding te traceback in the error message I can confirm this is being investigated in a Cisco internal bug:
CSCtj22513 platform assert failure traceback seen on modifying interface
This is fixed through:
CSCtk56241 crash noticed after nile assert error messages
This issue is fixed in IOS version 12.2(52)EY2 which should be available on Cisco.com soon. You will be able to download the image from the following link:
http://www.cisco.com/cisco/software/navigator.html?mdfid=283052113&i=rm
The issue itself should not cause any issue (the crash will not occur in your version).
To prevent this upgrade to the mentioned version when it's available.
/gary
No problem, happy to help. If you could mark this question as 'answered' that would be great, thanks.
/gary
It seems that the same bug is striking back.
It turned out that CSCtk56241 was fixing assert messages and traffic loss problems but it appears that the fix made for that bug does not cover all possible triggers.
Development team has recently given to a TAC customer hitting the same issue with EY2 and engineering image which will supposdely fix the issue for good or in the worst scenario help troubleshoot the problem further.
Likely EY3 will contain the final fix.
Anyway you'd better monitor the bug to see when it gets updated with the final resolution notes.
Riccardo
17 Replies 17
garhall
/gary
Thank you.
/gary
ruslank
After upgrading software to version 12.2(52)EY2:
Cisco IOS Software, ME380x Software (ME380x-UNIVERSALK9-M), Version 12.2(52)EY2, RELEASE SOFTWARE (fc1)
License Level: MetroIPServices
I got very similiar log messages:
Jun 30 2011 10:53:34.108 EET: platform assert failure: 0: ../src-nile/src-asic-nile/nile_adjmgr.c: 6662: adjmgr_l3_switch_nh_to_ucast
Jun 30 2011 10:53:34.108 EET: -Traceback= 4252E4 540460 DB0FA0 B4472C B3B0EC 420E98 423108 B383A0 B39C90 DE6088 DDCB10
Jun 30 2011 10:53:34.108 EET: Assert adjmgr_l3_switch_nh_to_ucast mac (0013.8f24.020a) vlan 1553
Jun 30 2011 11:47:00.571 EET: platform assert failure: 0: ../src-nile/src-asic-nile/nile_adjmgr.c: 6585: adjmgr_l3_switch_nh_to_flood
Jun 30 2011 11:47:00.571 EET: -Traceback= 4252E4 5409F4 DB1050 B44D9C B3B8E8 4245B4 424C54 DE6088 DDCB10
Jun 30 2011 11:47:00.571 EET: Assert  adjmgr_l3_switch_nh_to_flood mac (0013.7737.f95f) vlan 1851
This is the same BUG or second one?
Thank you.
Riccardo
I installed version 12.2(52)EY2a and this error message is gone!!!
Now with version 12.2(52)EY2a I got new crash:
Aug 17 2011 14:33:00.978 EET: %PLATFORM_NCEF-3-ADJ:
Null interface handle for if_number 4237 Adj hdl 175903056,Midchain Adj NO
-Traceback= DB060C DA0C68 DA3B90 D9C00C 12DB698 E79F74 E7D408 E7D8F8 17DB8D4 1458440 145A81C 145C008 145C370 145D50C 17990E4 1798630
Maybe you can help to understand what is it mean?
Did the switch completely crash or did you just see that traceback but the switch did not reload?
If it did not crash I need the show log showing the messages before the traceback (including the traceback) and a show ver.
If it crashed I need the crashinfo file.
Where you configuring some command related to IP PIM by any chance? What exactly?
I might have an idea already but I need to double check.
Riccardo
Sorry for delay in the answer, but I update to new software and have the same problem:
Jan 12 2012 03:16:51.173 EET: %PLATFORM_NCEF-3-ADJ:
Null interface handle for if_number 4239 Adj hdl 174736464,Midchain Adj NO
-Traceback= DB23C0 DA2A1C DA5944 D9DDC0 12DD3FC E7BD28 E7F1BC E7F6AC 17DD62C 145A1A4 145C580 145DD6C 145E0D4 145F270 179AE3C 179A388
Jan 12 2012 03:26:54.829 EET: %PLATFORM_NCEF-3-ADJ:
Null interface handle for if_number 4239 Adj hdl 173238512,Midchain Adj NO
Jan 12 2012 06:08:09.099 EET: %PLATFORM_NCEF-3-ADJ:
Null interface handle for if_number 4239 Adj hdl 170613168,Midchain Adj NO
Jan 12 2012 08:13:58.530 EET: %PLATFORM_NCEF-3-ADJ:
Null interface handle for if_number 4239 Adj hdl 174753264,Midchain Adj NO
My software version:
# sh version
Cisco IOS Software, ME380x Software (ME380x-UNIVERSALK9-M), Version 12.2(52)EY3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Fri 21-Oct-11 00:26 by prod_rel_team
License Type: Permanent
Next reload license Level: MetroIPServices
Traceback is appears after restart cisco.
Thank you.
please see my previous message
Switch is working and I don't understand that is not work correctly.
All messages after reload:
Jan 12 02:00:01 ME3800x 52633: Jan 12 2012 02:00:00.273 EET: %SYS-5-RELOAD: Reload requested by ruslan on vty1 (78.158.0.65). Reload reason: Reason unspecified
Jan 12 02:06:03 ME3800x 614: Jan 12 2012 02:06:02.681 EET: %DHCP_SNOOPING-6-AGENT_OPERATION_SUCCEEDED: DHCP snooping database Read succeeded.
Jan 12 02:06:07 ME3800x 615: Jan 12 2012 02:06:06.779 EET: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 1
Jan 12 02:06:07 ME3800x 616: Jan 12 2012 02:06:07.392 EET: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 78.158.8.1 on interface Vlan851
Jan 12 02:06:07 ME3800x 617: Jan 12 2012 02:06:07.392 EET: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 78.158.8.1 on interface Vlan852
Jan 12 02:06:07 ME3800x 618: Jan 12 2012 02:06:07.392 EET: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 78.158.8.1 on interface Vlan951
Jan 12 02:06:07 ME3800x 619: Jan 12 2012 02:06:07.392 EET: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 78.158.8.1 on interface Vlan952
Jan 12 02:06:07 ME3800x 620: Jan 12 2012 02:06:07.392 EET: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 78.158.8.1 on interface Vlan953
Jan 12 02:06:08 ME3800x 621: Jan 12 2012 02:06:07.392 EET: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 78.158.8.1 on interface Vlan954
Jan 12 02:06:08 ME3800x 622: Jan 12 2012 02:06:07.785 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan951, changed state to up
Jan 12 02:06:08 ME3800x 623: Jan 12 2012 02:06:07.785 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan952, changed state to up
Jan 12 02:06:08 ME3800x 624: Jan 12 2012 02:06:07.785 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan953, changed state to up
Jan 12 02:06:08 ME3800x 625: Jan 12 2012 02:06:07.785 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan954, changed state to up
Jan 12 02:06:08 ME3800x 626: Jan 12 2012 02:06:08.013 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan851, changed state to up
Jan 12 02:06:09 ME3800x 627: Jan 12 2012 02:06:08.013 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan852, changed state to up
Jan 12 02:06:10 ME3800x 628: Jan 12 2012 02:06:09.869 EET: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 48
Jan 12 02:06:10 ME3800x 629: Jan 12 2012 02:06:10.420 EET: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 78.158.8.1 on interface Vlan1058
Jan 12 02:06:10 ME3800x 630: Jan 12 2012 02:06:10.876 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1058, changed state to up
Jan 12 02:06:12 ME3800x 631: Jan 12 2012 02:06:11.426 EET: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 78.158.8.1 on interface Vlan47
Jan 12 02:06:12 ME3800x 632: Jan 12 2012 02:06:11.788 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan47, changed state to up
Jan 12 03:16:52 ME3800x 633: Jan 12 2012 03:16:51.173 EET: %PLATFORM_NCEF-3-ADJ:
Jan 12 03:16:52 ME3800x 634: Null interface handle for if_number 4239 Adj hdl 174736464,Midchain Adj NO
Jan 12 03:16:52 ME3800x 635: -Traceback= DB23C0 DA2A1C DA5944 D9DDC0 12DD3FC E7BD28 E7F1BC E7F6AC 17DD62C 145A1A4 145C580 145DD6C 145E0D4 145F270 179AE3C 179A388
Jan 12 03:26:55 ME3800x 638: -Traceback= DB23C0 DA2A1C DA5944 D9DDC0 12DD3FC E7BD28 E7F1BC E7F6AC 17DD62C 145A1A4 145C580 145DD6C 145E0D4 145F270 179AE3C 179A388
Jan 12 06:08:10 ME3800x 639: Jan 12 2012 06:08:09.099 EET: %PLATFORM_NCEF-3-ADJ:
Jan 12 06:08:10 ME3800x 640: Null interface handle for if_number 4239 Adj hdl 170613168,Midchain Adj NO
Jan 12 06:08:10 ME3800x 641: -Traceback= DB23C0 DA2A1C DA5944 D9DDC0 12DD3FC E7BD28 E7F1BC E7F6AC 17DD62C 145A1A4 145C580 145DD6C 145E0D4 145F270 179AE3C 179A388
Jan 12 08:13:59 ME3800x 642: Jan 12 2012 08:13:58.530 EET: %PLATFORM_NCEF-3-ADJ:
Jan 12 08:13:59 ME3800x 643: Null interface handle for if_number 4239 Adj hdl 174753264,Midchain Adj NO
Jan 12 08:13:59 ME3800x 644: -Traceback= DB23C0 DA2A1C DA5944 D9DDC0 12DD3FC E7BD28 E7F1BC E7F6AC 17DD62C 145A1A4 145C580 145DD6C 145E0D4 145F270 179AE3C 179A388
#sh version
Image text-base: 0x00003000, data-base: 0x0221CDF4
3800-fst-zad20 uptime is 12 hours, 53 minutes
System restarted at 02:01:05 EET Thu Jan 12 2012
System image file is "flash:/me380x-universalk9-mz.122-52.EY3a/me380x-universalk9-mz.122-52.EY3a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ME-3800X-24FS-M (PowerPC8572) processor (revision A0) with 1015808K/32760K bytes of memory.
Processor board ID FOC1511X2C9
Last reset from power-on
180 Virtual Ethernet interfaces
25 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
1536K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 44:E4:D9:9A:54:80
Motherboard assembly number     : 73-12068-07
Motherboard serial number       : FOC151001TD
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : ME-3800X-24FS-M
System serial number            : FOC1511X2C9
Top Assembly Part Number        : 800-31465-01
Top Assembly Revision Number    : A0
Version ID                      : V01
CLEI Code Number                : IPMSW00DRA
Configuration register is 0xF
Switch is working
Yes we are using multicast routing
Example of configuration:
interface Vlan101
ip address 78.158.1.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim passive
end
interface Vlan3001
ip address 78.158.0.73 255.255.255.252
no ip proxy-arp
ip pim sparse-mode
ip ospf network point-to-point
ip ospf hello-interval 1
hold-queue 4096 in
hold-queue 4096 out
end
#sh ip igmp ssm-mapping
SSM Mapping  : Enabled
DNS Lookup   : Enabled
Mcast domain : stream.fastlink.lt
Name servers : 78.158.0.2
               78.158.0.65
can you tell me the last command that was entered right before the traceback (i.e. interface svi removed, pim related command added or removed etc.)? Please also check if you have scripts running that make configuration changes.
Riccardo
I'm post full log of cisco after restart. No changes in the configuration, no connection to managment.
Sheduled reload at 02:00:
First error:
the commands which are typed are not showing in the log.
Are you 100% sure that you or anybody else (scripts included) did not make any single change from the time the switch was reloaded and the time the first traceback was printed?
Riccardo
