IDSM-2 with VSS system
asabagh
We are looking forward to install a Cisco 6513 with IDSM-2 in each chassis in a VSS mode. Does anyone have an experience with the configuration of the 6513 ?  Also, lets assume I installed one active IDSM in each chassis with identical configuration... what happens when one of them fails ?
Appreciate your Support.
Reza Sharifi
Hi Amro,
You would need to have one IDSM-2 in each chassis, because when the active VSS device fails the entire box will fail.
refer to this paper for more info on how to deploy IDSM in VSS:
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c72b.shtml#idsm
Reza
Thank you Raza..
I have read the document. But what I am interested in is how the configuration would look like in case of Promescouse mode ot inline mode.
Amro
Amro,
Did you ever get any  information about this?  I am also planning on implementing VSS with each chassis having an IDSM module.  Haven't figured out how to best deploy it (with configurations)
Thank you, Brian
