ME3400 drops traffic after configuration changes
aking
I have a ME 3400 that is acting flaky.  I have this device acting as a distribution switch and it is reachable on VLAN 127, which is one of the VLANS trunked to our core network.   When I try to configure one of the fastethernet ports (changing duplex; doing a shut / no shut), it causes my GI uplink and VLAN 127 to go down.  Sometimes it comes back up, sometimes it doesnt.  I am access the device over this GI uplink so I obviously I lose connectivity.  The fastethernet port isn't even in the same VLAN.
Any ideas from anyone?
majority of config is:
spanning-tree mode rapid-pvst
no spanning-tree optimize bpdu transmission
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 2
name GLOBAL
vlan 3
vlan 50
name SECURITY
vlan 51
name RemoteSecurity
vlan 113
name OceanShoresLAN
vlan 117
name ElmaLAN
vlan 118
name MonteLan
vlan 127
name Management
vlan 128
vlan 182
name RemoteVoIP
vlan 200
lldp run
interface FastEthernet0/1
switchport access vlan 3
duplex full
interface FastEthernet0/2
shutdown
interface FastEthernet0/3
shutdown
interface FastEthernet0/4
shutdown
interface FastEthernet0/5
shutdown
interface FastEthernet0/6
shutdown
interface FastEthernet0/24
shutdown
interface GigabitEthernet0/1
port-type nni
interface GigabitEthernet0/2
port-type nni
switchport trunk native vlan 2
switchport trunk allowed vlan 1,50,51,113,117,118,127,182
switchport mode trunk
interface Vlan1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface Vlan127
ip address 172.16.127.xxx  255.255.255.0
no ip route-cache
no ip mroute-cache
Thanks for your consideration...
Alice
Fabienne Stephanoff
Hello Alice,
The behavior is quite strange indeed. When you say the link goes down, are you referring to the line protocol, spanning tree not forwarding, link stays up but not able to ping across? Do you have any log messages generated as a result? You may need to open a TAC case on this issue. I doubt it will be an easy fix. You can open the TAC case from this tool.
Fabienne.
