MEM upgrade for 3600
josephschung
Dear Sir,
We need to upgrade the flash memory of 3600 router, but find the 16MB(MEM3600-16FC= (PCMCIA) or MEM3600-16FS (SIMM)) is not available.
Can we use the memory for 3800 routers such as MEM3800-64CF= for 3600?
Thanks.
Jagdeep Gambhir
Level 10
Level 10
Joe,
I'm not sure if you can use it, but I did found a substitute part for the 20mb flash card which is MEM-I/O-FLC20M.
You might want to verify with presales department and find out the cost for it. They could also help you find out the cost for a 16mb flash card for the 3600.
~JG
