Memory Capacity on Catalyst 6513
peter.tan
Community Member
How do I verify that the following have been installed in a Catalyst 6513 switch:
MEM-SUP720-SP-1GB
MEM-MSFC3-1GB
ankbhasi
Hi Peter,
If you issue a "show version" you can see the MSFC DRAM which should display 1 GB in total and when you issue "remote command switch sh version" you will get the DRAM installed onm supervisor engine which should be 1 GB in total.
If you have any doubt please paste the output of both the commands.
HTH,
Ankur
*Pls rate all helpfull post
Thanks, Ankur.
hoogen_82
Level 9
Level 9
Post your show version.
-Hoogen
