Memory Sanitization
bryantsteve
Level 4
Level 4
Need to dispose of 2900,4000, and 5000 series switches and need to permanently remove all non violatile memory from cards and processors. What is procedure to do this? Thanks
Edison Ortiz
NVRAM is on the motherboard. If you want to remove the configuration, just type wr erase.
HTH,
__
Edison.
