Meraki MX, switch and AP configuration
BHconsultants88
Hi. I hope someone can help with this. Here's a summary of my configuration
MX64 Firewall
IP Address: 10.10.10.254 /24
VLAN1: 10.10.10.10
VLAN2: 192.168.10.10
VLAN3: 172.16.10.10
MX64 Interfaces:
Port 1: vlan1 access
Port 2: vlan1 access
Port 3: vlan1 access
Port 4: vlan 2 access
MX120 Switch
IP Address: 192.168.10.252 /24
Ports 1-6 access - vlan 2
Ports 7-8 trunk - native vlan1 - all vlans allowed
Port 1 of MX connects to a fibre media converter which in turn connects to port 8 of MS120 switch. Both MX and MS devices are up. However, when connecting laptop to switchports 1-6, I get no IP address and there is no Internet activity. The AP also connects to these ports and as a result is not working. If the config looks ok, could the problem be being caused by the media converter?
What am I doing wrong???
Hello
The port from the MX to the MS should be trunked
Also have you a attached your ISP router the internet port of the MX
On the MX what does the application status/route table show and what mode do you have the l3 vlans in?
Kind Regards
Paul
