Meraki Port Isolation
Xiaolong-uk
Guys,
I am wondering if you can help?  Im trying to determine if port isolation is supported across Meraki switches, specifically the MS355 when operating in a stack.  The documentation as with all Meraki products/features is not very conclusive.  There is a statement at the following link Restricting Traffic with Isolated Switch Ports - Cisco Meraki, that states the following.
For MS210, MS225, and MS250 series switches, port isolation is only supported on the first 24 ports
Port isolation is not supported across stack members
But this is all in the same information bubble as if it's implying this about only the MS210, 225 and 250.
Has anyone tried deploying this feature on a stack, and if it doesn't work, do you understand the reason why?  I have a theory that if the stacking is done via standard ethernet and .1q, then I can understand why port isolation may not be applied.
Many thanks in advance
0 Replies 0
