08-16-2023 03:20 AM
Hi guys
I have an issue with 1 of my switches, last week I did a firmware upgrade now my switch can't fetch configurations from Meraki cloud.
can you guys help
Thank you
08-16-2023 03:36 AM
Hi @Motswahole is the device registered to the cloud at all? Are all ports/IP's open on your firewall to allow cloud comms?
08-16-2023 03:52 AM
Yes, but the issue started after firmware upgrade
08-16-2023 05:03 AM
In a situation like this, I would directly open a support ticket to do some live troubleshooting.
08-16-2023 10:07 AM
@Motswahole , as mentioned below open a case with Meraki support to either t/shoot or rollback.
08-16-2023 07:37 AM
Have you tried rolling back the upgrade to confirm it was definitely the upgrade that broke it?
08-16-2023 04:14 PM
You need Meraki support to fix that. It doesn't take long usually.
