05-31-2021 10:33 AM
I have a solution the customer need a modular core c9606R and the edge switches are Meraki MS225 stackable.
the problems is : the transceivers supported by C9606R (SFP-10G-LR) are not compatible with MS225 (MA-SFP-10GBLR)
IF I installed SFP-10G-LR on C9606R and MA-SFP-10GBLR on MS225 the link will be up or we will have a problem
Solved! Go to Solution.
06-01-2021 12:14 AM
- If both ends use their own compatible transceivers it should work.
M.
06-01-2021 12:14 AM
M.
