Metric mismatch in Eigrp
Sanjib Pradhan
Please someone help me to calculate metric in Eigrp. Please find below Bandwidth and Delay.
R2#sh int s0/1
Serial0/1 is up, line protocol is up
  Hardware is GT96K Serial
  Internet address is 20.1.1.2/24
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  CRC checking enabled
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
     1183 packets input, 77832 bytes, 0 no buffer
     Received 425 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1158 packets output, 76032 bytes, 0 underruns
     0 output errors, 0 collisions, 6 interface resets
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
R2#sh ip route | in 2.2.2.0
D       2.2.2.0 [90/2297856] via 20.1.1.1, 00:59:26, Serial0/1
Metric calculation of EIGRP:
[(10,000,000 / 1544) +2000 ] * 256 =(6476+2000)*256=8476*256=2169856
This value is mismathed with EIGRP calculated metric(i.e 2297856). Please someone figerout if some thing I have missed during calculation.
2 Accepted Solutions
Sandeep Choudhary
HI Sanjib,
Metric = 256*[10^7/BW(min)] + [sum of delay]/10
Metric = 256*[10^7/1544] + (20000+5000)/10]
Metric = 256*[6476+2500]
Metric = 2297856
  • We see the minumum bandwidth to reach the destination  is 1544Kbps
  • Default delay on the link to reach the destination (serial link) is 20000 microseconds.
  • Default delay of the loopback interface is 5000 microseconds.
Dont forget to rate helpful posts.
Peter Paluch
Sanjib,
The 2.2.2.0/24 network is on the loopback on R3, right? In that case, you would need to take the loopback's bandwidth and delay into account as well. By default, loopback BW is set to 8 Gbps (more than the serial link's) and delay is 5000 usec, so the resulting metric would be
[(10,000,000 / 1544) + 2500 ] * 256 = 2297856
which matches the show ip route output.
Best regards,
Peter
Sandeep Choudhary
HI Sanjib,
Metric = 2297856
Peter Paluch
Sanjib,
Best regards,
Peter
Thank you so much Mr. Sandeep and Peter.....
