MIB help?
esink4601
Visitor
Hello everyone,
I'm trying to get some MIBs for some new ISR 4331's we've deployed. Issue is that I've never done MIBs for Cisco gear before. I'm pretty accostomed to a device having like one MIB with all the OIDs I'd ever need in it. I'm starting to figure out this is not how it works for Cisco.
Can someone kind of guide me to how I would find the MIBs for CPU and Interface stats for the ISR 4331?
thanks!
/Evan
Steve Fuller
Level 11
Level 11
Hi Evan,
A good place to start is the SNMP Object Navigator as this allows you to search, translate OID, download MIBs etc.
For what you need you should be able to use the following MIBs
For a list of all MIBs supported on the ISR 4431, and links to download, see the Cisco ISR 4000 SNMP MIB Support List.
Ganesh Hariharan
Hello everyone,
thanks!
/Evan
Hi Evan,
As stated by Steve you can start with SNMP object navigator and link for FTP which gives MIB support.
Have a look on the below link MIB specification Guide ISR 4000 which explains on how to download MIB and configure.
Hope it Helps..
-GI
Rate if it Helps
