Migrating from 2960 to 9200
vban
we are migrating from 2960 to 9200 , what are the steps do I need to follow to start the process of migration.
Single or stacked switches? do they have same port numbers? same port types? Generally speaking copying/pasting the config from the 2960 to the 2900 would do the job. However, if the switches have different ports numbers then you would need to apply each port type config to the interested ports on the 9200. And if they have different ports ID for instance Gi0/1 versus Gi1/0/1 then you need to edit that on a text file before pasting to the 9200. Also, if you are using dot1x some of the commands syntax might be slightly different. What I would recommend would be copying/pasting the global commands section by section, and then move to the ports configs trying couple first and then do it on the remainder ports.
vban
Single not stacked , but may be we can stack them. 9200 have Gigabit Ethernet.
No worries. Migrating from a single 2960 to a single 2900 is even easier. Same logic mentioned in my previous post would still apply.
@vban
Do not forget about vlan.dat /
Save the running configuration of all 2960 switches (100% do it )
show run | redirect flash:/backup-2960.cfg
copy flash:/backup-2960.cfg tftp://<server-ip>
Thanks!
