Migration from Extreme EXOS to Catalyst 9000
mohammede
Hello community!
Does anyone know if there is a tool to convert configuration from an EXOS Extreme Switches to Cisco Catalyst 9000
Or has anyone ever done this conversion?
Reza Sharifi
There is a cross reference (link below), but I don't think there is a tool to convert the config from Extreme to Cisco.
https://documentation.extremenetworks.com/CLI_X-Ref/1.0/CLI_X-Ref_Guide_1.0.pdf?_ga=2.55976619.1864167578.1649874726-1003560259.1649874726
mohammede
Thank you Reza for the refrenece
the 'sh run' equivalent in EXOS is 'show configuration' as far as I recall. Post the output of that...
Thanks for yr response ,
There are dozens of switches Extreme that will be replaced by cisco, if there was one, it would be easy ,,
