migration from rapid-pvst to mst
Per_Cas
Hello forum guys,
I have three switches in LAN network which run in rapid-pvst mode. I would like migrate to mst.
I try to search cisco documentation and I found that migration from 802.1D to 802.1w is cousing outage:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/72844-MST.html
However I did not find any documents who could tell me about outage during migration from 802.1w to 802.1s. I would like to avoid any connectivity disruption if there is any during migration. How can I achieve this? As far as I know, mst has all features like rstp plus it can group set of vlans in defined instances, so theoretically, it should not be any connectivity disruption, should be?
Paul Chapman
Level 4
Level 4
Hi --
Any STP mode change will cause a 5-30 second disruption assuming you don't accidentally make an error.  The scope of the outage is based on where the STP root is and how many switches have to recalculate the tree.
PSC
Paul Chapman
Level 4
Level 4
Hi --
PSC
Hi Paul,
Even change from rapid spt to mst ( so in fact from rstp to rstp ) ?
You're proposing to change the protocol the switches use to negotiate.  Even if you configure multiple switches simultaneously, they still have to exchange the new type of BPDU and calculate the new topology.
PSC
