migration to vss for 4500E
Hello community!
I have one 4507R+E with dual Sup7L-E (ADV-Enterprise) and one 4506E with Sup6L-E. A want create wss so I have several questions.
Q #1: New software release of Sup7L-E still need to have identical number of slots in vss chaises? No plans to change this in next versions?
Yes - No
If Yes, I need to purchase one chaise 4506E. Transfer booth Sup7L-E from 4507R+E to different 4506E
And make a configuration of 2x 4506E with Sup7L-E in booth chaises.
And Q#2. Can I transfer both Sup7L-E (ADV-Enterprise) from 4507R+E to different 4506E and keep license level of both Sup7L-E  as ADV-Enterprise.
TNX for answers!
Sergiy.
Reza Sharifi
Hi Sergiy,
Q1-In order for VSS to work, you need to have identical sups in each chassis with identical software and license. There are no plans to change that.
Q2-Legally no, but talk to your Cisco sales rep about that. They can probably help you with a solution that is cost effective.
Reza Sharifi
Hi Sergiy,
dkalinsky
Hello, Sergiy
Q1 - Here is a hardware requirement for VSS in IOS XE 3.5.0E:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-5-0E/15-21E/configuration/guide/config/vss.html#pgfId-1053927
As you can see your Sup7L-E is supported here.
And here is an information about Assymetric chassis support for VSS in IOS XE 3.5.0E:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-5-0E/15-21E/configuration/guide/config/vss.html#37306
So, with IOS XE > 3.5.0E you can built VSS between assymetric chassis.
