Minimum password length policy for switch
Hello Guys.
I have several switches running on IOS XE, i was trying to set the minimum password lenth on them but i cant find the command to do that, i need help, i tried "security passwords min-length " but command is not available.
Regards.
@Giuseppe Larosa  does the "aaa common-criteria policy" only affect local users? what if a user is logging in using radius authentication?
Hello @vitumbiko nkhwazi ,
we should look in Security command reference for IOS XE
the config guide
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_aaa/configuration/15-e/sec-usr-aaa-15-e-book/sec-aaa-comm-criteria-pwd.html
provides also a reference to two RFC:
RFC 2865
Remote Authentication Dial-in User Service
RFC 3576
Dynamic Authorization Extensions to RADIUS
but the config example looks like to apply to local users only. so only the command reference can clarify this point.
Hope to help
Giuseppe
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_aaa/configuration/xe-16-12/sec-usr-aaa-xe-16-12-book/sec-aaa-comm-criteria-pwd.html#GUID-E534CBDE-E6CD-4651-8CA4-DA9D6EDA2740
 M.
