Miraki issue
shashanksgr251
Hi All..
Deployed Cisco Miraki on our infrastructure and now user reporting slowness and dis connectivity.
What could be the possibility of issue..
Bilal Nawaz
There are built in troubleshooting tools within the AP if you were to log on to it locally, but it's usually best to start with looking at the Meraki cloud dashboard, find out which host has a problem and drill more down to the AP, the SSID and the host/user. Check the ports that the meraki AP connects to for any errors and ensure connectivity to the cloud remains stable.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
shashanksgr251
Below is logs.
Apr 16 12:57:27 IN-WiFi-02 Hermes IN-L0553 802.1X authentication radio: 1, vap: 0, identity: akumar7@corp.yodlee.com  more »
Apr 16 12:57:27 IN-WiFi-02 Hermes IN-L0553 802.1X EAP success radio: 1, vap: 0, identity: akumar7@corp.yodlee.com  more »
Apr 16 12:57:27 IN-WiFi-02 Hermes IN-L0553 RADIUS response radio: 1, vap: 0, group:   more »
Apr 16 12:57:27 IN-WiFi-02 Hermes IN-L0553 802.11 association channel: 161, rssi: 48
Apr 16 12:57:22 IN-WiFi-02 Hermes IN-L0553 802.11 disassociation unknown reason
Apr 16 12:48:15 IN-WiFi-02 Hermes IN-L0553 802.1X authentication radio: 1, vap: 0, identity: akumar7@corp.yodlee.com  more »
Apr 16 12:48:15 IN-WiFi-02 Hermes IN-L0553 802.1X EAP success radio: 1, vap: 0, identity: akumar7@corp.yodlee.com  more »
Apr 16 12:48:15 IN-WiFi-02 Hermes IN-L0553 RADIUS response radio: 1, vap: 0, group:   more »
Apr 16 12:48:15 IN-WiFi-02 Hermes IN-L0553 802.11 association channel: 161, rssi: 47
Apr 16 12:48:10 IN-WiFi-05 Hermes IN-L0553 802.11 disassociation unknown reason
Apr 16 12:46:57 IN-Wifi-6 Hermes IN-L0553 802.11 disassociation unknown reason
Apr 16 12:39:57 IN-WiFi-02 Hermes IN-L0553 802.11 disassociation unknown reason
Apr 16 12:39:48 IN-WiFi-05 Hermes IN-L0553 802.1X authentication radio: 1, vap: 0, identity: akumar7@corp.yodlee.com  more »
Apr 16 12:39:48 IN-WiFi-05 Hermes IN-L0553 802.11 association channel: 44, rssi: 32
Apr 16 12:39:48 IN-WiFi-05 Hermes IN-L0553 OKC match radio: 1, vap: 0, group:   more »
Apr 16 12:38:31 IN-Wifi-6 Hermes IN-L0553 802.1X authentication radio: 1, vap: 0, identity: akumar7@corp.yodlee.com
Apr 16 12:38:31 IN-Wifi-6 Hermes IN-L0553 PMKSA cache match radio: 1, vap: 0, group:   more »
Apr 16 12:37:39 IN-WiFi-02 Hermes IN-L0553 802.1X authentication radio: 1, vap: 0, identity: akumar7@corp.yodlee.com  more »
Apr 16 12:37:39 IN-WiFi-02 Hermes IN-L0553 OKC match radio: 1, vap: 0, group:   more »
Apr 16 12:37:39 IN-WiFi-02 Hermes IN-L0553 802.11 association channel: 161, rssi: 25
Apr 16 12:07:29 IN-Wifi-6 Hermes IN-L0553 802.1X authentication radio: 1, vap: 0, identity: akumar7@corp.yodlee.com
Apr 16 12:07:29 IN-Wifi-6 Hermes IN-L0553 802.1X EAP success radio: 1, vap: 0, identity: akumar7@corp.yodlee.com
Apr 16 12:07:29 IN-Wifi-6 Hermes IN-L0553 RADIUS response radio: 1, vap: 0, group:   more »
Take this up with Meraki support.
