Misconfigured switch?
Hello everyone
I was suggested to go here from the MS technet forums, as my problem originally was related to TFTP, PXE and ConfigMgr, but it seems the problem can be a cisco router.
I copied the thread i made:
m having a rather peculiar issue with horrendously slow downloading of the boot.wim filer over TFTP. This is for a customer, who has an old ConfiMgr environment and  new one which I have recently implemented.
The old environment is configured almost identical to the new environment
-RamDiskTFTPBlockSize is set to 16384 in both cases
-RamDiskTFTPWindowSize is set to the default 4 in both cases
-Send Receive Buffers is identical at 2mb on both
Difference: The new environment has 2 Cisco 3750x  switches
Switches are configured as follows:
Switch1:
interface TenGigabitEthernet1/1/1
switchport access vlan 122
switchport mode access
flowcontrol receive on
spanning-tree portfast
interface TenGigabitEthernet1/1/2
Switch2:
The difference is immense. 15 minutes on the new environment, compared to 30 seconds on the old. The only difference as far as I can tell is the fact the there is a switch connected to the new one, so as far as I can see this is only obstacle that could provide such a drastic stop.
Am I right in assuming this, or is there anything else that could account for this difference?
Jimmy Johansson
How is your network topology? I just find it odd you're using a L3-switch in the access layer and ten gigabit-interfaces in access mode when usually they're used for trunking.
I frankly don't know. Im purely a client management specialist, and am unfortunately nowhere close to being as good with networks as I would like. Adding to this, this is for a client of mine, where I have little to no control over anything but servers I'm hired to work with.
Please check the port status
# show interface TenGigabitEthernet1/1/x on both the switches, and make sure that you are seeing correct speed/duplex.
Please check the counters for any errors.
#show interfaces counters errors
Antonio Knox
Level 7
Level 7
I'd try turning off flow control (no flowcontrol receive on)
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_cli/if_basic.html
Please rate if helpful.
