09-08-2015 12:38 PM - edited 03-08-2019 01:41 AM
Hi all,
I'm planning to change the power supplies on an Cat4500E chassis from 1300W (redundanty) to 2800W (redundanty).
Can I mix the two types of PSU's (keep the switch online during the swapping) or do I need to shutdown the chassis and change both?
Norbert
Solved! Go to Solution.
09-08-2015 02:50 PM
You can change the power supply one at a time but you can't leave two different power supplies for long because the system will "error-disable" one of the two.
09-08-2015 02:50 PM
09-09-2015 03:10 AM
But if the new one (2800w) is going err-disable, the old one (1300w) can not be changed without power off the swich, right?
