Mode change not accepted
mscomms
Hi There I am trying to configure a tunnel to carry CLNS traffic using the following config
interface Tunnel0
description *** OSI Tunnel to Langley ***
no ip address
clns router isis
isis metric 21 level-1
tunnel source Loopback0
tunnel destination xxx.xxx.x.x
tunnel mode eon
and I am getting an error message of "Mode change not accepted"
The router is a 3825 running 12.4(15)T7
This config is working fine on 3600 routers running 12.2(29b)& 12.2(12)
Anyone else had this problem and is there a fix
Cheers
Mike
8 Replies 8
Giuseppe Larosa
Hello Mike,
use a GRE tunnel instead
tunnel mode gre
on both ends
you may need to tune clns mtu and to disable hello padding to be able to setup IS-IS adjacency
I had used clns mtu 1460
Hope to help
Giuseppe
I could give that a try and I will if I do net get a resolution but I have 15 - 20 of these tunnels and i would like to keep them standard.
Peter Paluch
Hi Mike,
When exactly do you get that error message? Can you perhaps post a complete transcript?
I was able to replicate your configuration without problems on 12.4(12) IOS for 2691 series routers.
Best regards,
Peter
PENNER-DCNKR-02(config)#int tun 0
PENNER-DCNKR-02(config-if)#desc *** OSI tunnel to HX89 ***
PENNER-DCNKR-02(config-if)#clns router isis
PENNER-DCNKR-02(config-if)#isis metric 21 level-1
PENNER-DCNKR-02(config-if)#tun source lo0
PENNER-DCNKR-02(config-if)#tun dest xxx.xxx.x.x
PENNER-DCNKR-02(config-if)#tun mode eon
PENNER-DCNKR-02(config-if)#^Z
PENNER-DCNKR-02#wr
Building configuration...
[OK]
PENNER-DCNKR-02#sh int tun 0
Tunnel0 is up, line protocol is down
Hardware is Tunnel
Description: *** OSI tunnel to HX89 ***
MTU 1514 bytes, BW 9 Kbit/sec, DLY 500000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel source 213.186.5.172 (Loopback0), destination 213.186.5.3
Tunnel protocol/transport uninitialized
Tunnel TTL 255
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Last input never, output 00:00:24, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3 packets output, 1625 bytes, 0 underruns
PENNER-DCNKR-02#
Here is the sh hard
PENNER-DCNKR-02#sh hard
Cisco IOS Software, 3800 Software (C3825-IPBASE-M), Version 12.4(15)T7, RELEASE
SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Aug-08 23:17 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
PENNER-DCNKR-02 uptime is 11 weeks, 2 days, 15 minutes
System returned to ROM by reload at 09:17:05 UTC Wed Aug 5 2009
System image file is "flash:c3825-ipbase-mz.124-15.T7.bin"
Cisco 3825 (revision 1.2) with 226304K/35840K bytes of memory.
Processor board ID FCZ131773AY
3 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
Hi Mike,
Two suggestions:
1.) Try to create a completely new Tunnel interface (Tunnel100 for example) and use the tunnel mode eon as the very first command on that interface. Only then try to add the remaining commands.
2.) I noticed that the IOS running on your 3825 is IP Base. Honestly, I am not sure if the EON encapsulation is available in the IP Base feature set. I have been using Advanced IP Services for my experiment.
Best regards,
Peter
I tried 1 early on to no effect but I had noticed that it was running IPBASE as well and have just upgraded to ENTBASE and it now accepts the command, Thanks for your help
Mike
Mike,
You are welcome. And thanks for asking - this has been my first "exposure" to the EON type of tunnels. Thanks to you I've learned something new.
Best regards,
Peter
