Moderate CPU, slow ping
jasonmeyer
Have an odd problem that seems to get worse over time.  Ping times across vlans gets progressively slower until packets start dropping on workstations/servers. Seems like a monthly occurrence.
Include a putty log of output from various show cpu/platform commands.
2 Accepted Solutions
Leo Laohoo
The supervisor card is running version 3.4.0. The last "digit" ends with a "0". I'll say that'll be the culprit right there.
My recommendation is upgrade the firmware to something more recent.
No, I won't "recommend" the version. Pick a version that has a very high last digit (more than "5") and read the Release Notes.
hard to say. You might want to upgrade to CAT4500E Universal Image cat4500e-universal.SPA.03.11.01.E.152-7.E1.bin., which is the latest release...
Can you post the running configuration of the switch ?
8 Replies 8
Leo Laohoo
I know I need to do a firmware and rommon upgrade, but this started happening a month or two ago. A reload clears things up.
here is the running config
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.01.07 15:21:08 =~=~=~=~=~=~=~=~=~=~=~=
show run
Building configuration...
Current configuration : 18227 bytes
! Last configuration change at 14:59:10 CST Tue Jan 7 2020
version 15.1
no service pad
service compress-config
hostname ISD623Core-4503
boot-start-marker
boot system flash bootflash:cat4500e-universal.SPA.03.04.00.SG.151-2.SG.bin
boot-end-marker
vrf definition mgmtVrf
address-family ipv4
exit-address-family
--More--   !
address-family ipv6
exit-address-family
logging console warnings
enable password #######
no aaa new-model
clock timezone CST -6 0
flow record r1
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect ipv4 dscp
collect transport tcp source-port
collect transport tcp destination-port
collect transport tcp flags
collect transport udp source-port
--More--   collect transport udp destination-port
collect interface output
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow record netmap
flow exporter netmap
destination 10.249.254.23
transport udp 2055
flow monitor m1
record r1
exporter netmap
cache timeout inactive 30
cache timeout active 60
cache entries 1000
--More--  !
ip vrf Liin-vrf
ip domain-name ad.roseville.k12.mn.us
ip name-server 10.249.254.35
ip name-server 10.249.254.34
ipv6 multicast rpf use-bgp
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2
--More--   name admin
vlan 5
name GuestWLAN
vlan 6
name RoseAirNet
vlan 7
name EMPhones
vlan 20
name internet
vlan 21
name BH
vlan 22
name EDW
vlan 23
name FV
--More--  vlan 24
name iPrisim-Bridge
vlan 25
name inet
vlan 26
name public
vlan 99
name CTV
vlan 171
name NSCC_vBrick
vlan 198
name RoseAirNetM
vlan 253
name RVDATA
vlan 313
name iSCSI
--More--  !
vlan 353
name RVVOICE
vlan 357
name city-voice
vlan 1701
name vbrick
vlan 2102
name DC_LAN
vlan 2103
name HS_LAN
vlan 2104
name HAR-Data
vlan 2105
name MS_LAN
vlan 2106
--More--   name BH_LAN
vlan 2107
name CP_LAN
vlan 2108
name EG_LAN
vlan 2109
name EDW_LAN
vlan 2110
name FH_LAN
vlan 2111
name LC_LAN
vlan 2112
name PCS_LAN
vlan 2113
name FV_LAN
--More--  vlan 2115
name HS_StLAN
vlan 2116
name HSBells
vlan 2148
name Switch-MGT
vlan 3102
name DC_Voice
vlan 3103
name HS_Voice
vlan 3104
name HB_Voice
vlan 3105
name MS_Voice
vlan 3106
name BH_Voice
--More--  !
vlan 3107
name CP_Voice
vlan 3108
name EG_Voice
vlan 3109
name EDW_Voice
vlan 3110
name FH_Voice
vlan 3111
name LC_Voice
vlan 3112
name PCS_Voice
vlan 3113
name FV_Voice
--More--  !
interface Port-channel1
description COR-RASCore
switchport
switchport trunk allowed vlan 2,5-7,20-26,99,171,198,253,313,353,357,1701
switchport trunk allowed vlan add 2102-2116,2148,3102-3113
switchport mode trunk
ip flow monitor m1 input
interface Port-channel2
description RASCore-ServerSwitch
switchport
interface Port-channel3
description RASCore-HSCore
--More--   switchport
switchport trunk allowed vlan add 2102-2115,2148,3102-3113
interface Port-channel5
description Wifi portchannel5
switchport
switchport trunk allowed vlan 2,5-7,21-23,198,2102-2115
interface FastEthernet1
vrf forwarding mgmtVrf
no ip address
shutdown
speed auto
duplex auto
interface TenGigabitEthernet1/1
description 8510 Uplink
--More--   switchport mode trunk
interface TenGigabitEthernet1/2
switchport trunk allowed vlan 2,5-7,20-26,99,171,253,313,353,357,1701
interface TenGigabitEthernet1/3
description iBossLAN
switchport access vlan 2
switchport mode access
spanning-tree portfast
interface TenGigabitEthernet1/4
description iBoss Management
switchport access vlan 2103
interface GigabitEthernet2/1
--More--   switchport access vlan 20
interface GigabitEthernet2/2
switchport access vlan 3111
interface GigabitEthernet2/3
interface GigabitEthernet2/4
interface GigabitEthernet2/5
interface GigabitEthernet2/6
interface GigabitEthernet2/7
interface GigabitEthernet2/8
interface GigabitEthernet2/9
--More--  interface GigabitEthernet2/10
interface GigabitEthernet2/11
switchport trunk allowed vlan 2148
interface GigabitEthernet2/12
interface GigabitEthernet2/13
interface GigabitEthernet2/14
interface GigabitEthernet2/15
interface GigabitEthernet2/16
interface GigabitEthernet2/17
interface GigabitEthernet2/18
interface GigabitEthernet2/19
interface GigabitEthernet2/20
--More--  !
interface GigabitEthernet2/21
interface GigabitEthernet2/22
interface GigabitEthernet2/23
interface GigabitEthernet2/24
interface GigabitEthernet2/25
interface GigabitEthernet2/26
interface GigabitEthernet2/27
interface GigabitEthernet2/28
interface GigabitEthernet2/29
interface GigabitEthernet2/30
interface GigabitEthernet2/31
channel-group 5 mode on
interface GigabitEthernet2/32
description UpLink to Harambee
switchport trunk allowed vlan 2104,3104
interface GigabitEthernet2/33
description BigTripp connection
interface GigabitEthernet2/34
description iSCSI trunk
switchport trunk allowed vlan 313
interface GigabitEthernet2/35
description 5508Controller
interface GigabitEthernet2/36
description iPrismInternal
shutdown
interface GigabitEthernet2/37
description Sonicwall X1
interface GigabitEthernet2/38
description HS-Mitel
switchport access vlan 3103
--More--   spanning-tree portfast
interface GigabitEthernet2/39
channel-group 3 mode active
interface GigabitEthernet2/40
interface GigabitEthernet2/41
interface GigabitEthernet2/42
interface GigabitEthernet2/43
channel-group 2 mode active
interface GigabitEthernet2/44
interface GigabitEthernet2/45
interface GigabitEthernet2/46
--More--   switchport trunk allowed vlan add 2102-2116,2148,3102-3113
interface GigabitEthernet2/47
shutdown
channel-group 1 mode active
interface GigabitEthernet2/48
shutdown
interface TenGigabitEthernet3/1
interface TenGigabitEthernet3/2
interface TenGigabitEthernet3/3
--More--  !
interface TenGigabitEthernet3/4
interface TenGigabitEthernet3/5
interface TenGigabitEthernet3/6
interface TenGigabitEthernet3/7
interface TenGigabitEthernet3/8
interface TenGigabitEthernet3/9
interface TenGigabitEthernet3/10
interface TenGigabitEthernet3/11
interface TenGigabitEthernet3/12
description DC Uplink
switchport trunk allowed vlan 2,26,99,171,253,353,357,2102,2103,2105,2112,2115
switchport trunk allowed vlan add 2148,3102,3103
--More--  interface Vlan1
no ip address
interface Vlan2
ip address 10.249.254.254 255.255.0.0
ip helper-address 10.249.254.105
ip helper-address 10.103.254.6
ip helper-address 10.103.254.9
ip helper-address 10.113.254.6
ip helper-address 10.112.254.9
ip helper-address 10.105.255.255
ip directed-broadcast 101
interface Vlan5
ip address 10.30.1.254 255.255.0.0
interface Vlan6
ip address 10.99.1.254 255.255.0.0
ip helper-address 10.249.255.255
interface Vlan7
ip address 10.97.254.254 255.255.0.0
--More--  !
interface Vlan20
description internet
no ip address
interface Vlan21
ip address 10.106.254.254 255.255.0.0
ip helper-address 10.249.254.40
ip helper-address 10.249.254.120
ip helper-address 10.249.254.121
ip helper-address 10.249.254.122
ip helper-address 10.249.254.123
ip helper-address 10.249.254.124
ip helper-address 10.249.254.90
ip helper-address 10.249.254.91
ip helper-address 10.249.254.92
interface Vlan22
ip address 10.109.254.254 255.255.0.0
--More--   ip helper-address 10.249.254.122
interface Vlan23
ip address 10.113.254.254 255.255.0.0
interface Vlan24
no ip address
--More--  !
interface Vlan25
no ip address
interface Vlan26
no ip address
interface Vlan198
ip address 10.98.1.254 255.255.0.0
interface Vlan313
ip address 172.16.1.254 255.255.255.0
interface Vlan2102
ip address 10.102.254.254 255.255.0.0
--More--   ip helper-address 10.249.254.91
interface Vlan2103
ip address 10.103.254.254 255.255.0.0
interface Vlan2104
ip address 172.25.254.254 255.255.0.0
ip helper-address 10.112.254.8
ip helper-address 10.249.254.86
--More--   ip helper-address 10.249.254.87
ip helper-address 10.249.254.88
interface Vlan2105
ip address 10.105.254.254 255.255.0.0
--More--   ip directed-broadcast 101
interface Vlan2106
no ip address
interface Vlan2107
ip address 10.107.254.254 255.255.0.0
--More--   ip helper-address 10.249.254.90
interface Vlan2108
ip address 10.108.254.254 255.255.0.0
interface Vlan2109
no ip address
interface Vlan2110
ip address 10.110.254.254 255.255.0.0
interface Vlan2111
ip address 10.111.254.254 255.255.0.0
--More--   ip helper-address 10.249.254.40
interface Vlan2112
ip address 10.112.254.254 255.255.0.0
--More--  !
interface Vlan2113
no ip address
interface Vlan2114
no ip address
interface Vlan2115
ip address 10.115.254.254 255.255.0.0
--More--   ip helper-address 10.249.254.123
interface Vlan2116
ip address 10.116.1.254 255.255.255.0
interface Vlan2148
ip address 10.248.254.254 255.255.255.0
interface Vlan3102
ip address 10.202.1.254 255.255.255.0
interface Vlan3103
ip address 10.203.1.254 255.255.254.0
interface Vlan3104
ip address 10.204.1.254 255.255.255.0
interface Vlan3105
--More--   ip address 10.205.1.254 255.255.255.0
interface Vlan3106
ip address 10.206.1.254 255.255.255.0
interface Vlan3107
ip address 10.207.1.254 255.255.255.0
interface Vlan3108
ip address 10.208.1.254 255.255.255.0
interface Vlan3109
ip address 10.209.1.254 255.255.255.0
interface Vlan3110
ip address 10.210.1.254 255.255.255.0
interface Vlan3111
ip address 10.211.1.254 255.255.255.0
interface Vlan3112
ip address 10.212.1.254 255.255.255.0
--More--  interface Vlan3113
ip address 10.213.1.254 255.255.255.0
ip forward-protocol udp echo
ip http server
ip route profile
ip route 0.0.0.0 0.0.0.0 10.249.254.230
logging trap warnings
access-list 101 permit udp host 10.249.254.105 any eq echo
snmp-server community public RO
snmp-server location RAHS MDF Telco Racks
snmp-server contact helpdesk@isd623.org
line con 0
password #####
login
stopbits 1
line vty 0
password #####
--More--   login
length 0
line vty 1 4
login
length 0
line vty 5 15
login
ntp server 10.249.254.34
ntp server 10.249.254.35
end
ISD623Core-4503#
I am assuming i still have perform the ROMMON upgrade, then the firmware?
The latest RMMON version is 15.0(1r)SG16. Al thought it is a good idea but depending on the IOS you want to upgrade to you may not need to upgrade ROMMON. In any case, you would upgrade the ROMMON first and than the main IOS for the chassis.
Please make sure to read the release notes very carefully.
Well I was thinking 3.11.1E as its the latest.
That should work. I would just upgrade ROMMON first and than read the release notes for 11.01.E.1 to make sure you are not hitting a major bug.
