04-10-2011 02:51 PM - edited 03-06-2019 04:32 PM
Hi all,
Has any one seen a message similar to this one before ?
It started happening after I reboot my chassis during a IOS upgrade.
Until then everything was working as expected.
This is basically my configuration:
6513 chassis
Redundant WS-CAC-6000W power suplies
Redundant sup WS-SUP720-3B
WS-X6716-10GE
Plus some other line cards.
I also have a WS-C6K-13SLT-FAN2 fan tray just in case people ask.
I've re-sit this module just in case there was a bad contact, no luck so far.
Thank you in advance for any suggestions that might help address this issue.
Kind regards,
Nelson
04-10-2011 04:25 PM
Hi Nelson,
I don't think that the 6513 is NEBS compliment anyway. Only 6509-V-E is NEBS compliment
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_bulletin09186a00801a987d.html
What is installed in module 11?
Reza
04-10-2011 04:42 PM
Hi Reza,
Thanks for the reply, slot 11 has a WS-X6716-10GE module.
I realize that a 6513 chasis is not NEBS compliant, but that doesn't prevent using a WS-X6716-10GE card in it as long as I use a WS-C6K-13SLT-FAN2 fan tray with it in the chassis. This is according to the IOS release notes http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/hardware.html.
By the way, I'm running 12.2(33)SXI4a.
Nelson
04-10-2011 06:13 PM
Correct, it will not you prevent you from using a WS-X6716-10GE E
Is your WS-X6716-10GE copper of fiber?
Reza
04-10-2011 06:35 PM
Fiber.
Nelson
04-19-2011 07:02 PM
Just an update,
I got a replacement module and the everything started working again indicating a failure on the old module, 6716.
Thank you Reza for trying to help.
Nelson
04-19-2011 08:06 PM
Nelson,
Thanks for the update!!
Glad everything is working now
Reza
